| Posted by Dave on July 16, 2001 at 17:24:43: | |
| In response to Re: Refrigerator water line | |
: : I would like to be able to move my refrigerator frequestly without damaging the water supply line to the ice maker. Is there a good way of connecting this so that the strain is removed from the supply line and hook-up valve? Can plastic tubing be used sucessfully in lieu of copper line in this area? Thank you, Jeff : You are suppossed to coil the line in a spring shape up behind the fridge so that when you pull out the fridge, it uncoils to some extent. I have never used plastic...good luck
| There are none. |
