Re: piping for tiolet and faucets
Posted by mike myers on July 11, 2001 at 20:42:08:
In response to Re: piping for tiolet and faucets
Tough one...A platform (3/4" or whatever thickness you need to make up the difference)under the base of the toilet and tiled is one solution that works great and done correctly, can even add a style element to the overall job. You may be able to move the Tub/faucet valve by cutting an access hole from behind it. there are probably some straps and blocking holding it in its corrent position. It is possible that the manufacturer makes a trim kit for your problem as well....Good luck !
Replies to this post
There are none. |
