| Posted by mike myers on July 11, 2001 at 20:34:37: | |
| In response to Re: Sump pum check valve | |
Why not use a rubber/plastic one with hoseclamps? The install would be easier. To answer your question-yes 2 or 3 times around with teflon, wrapped in the same direction as you'd tighten the nut is fine for your drain line. Pipe thread sealant would also suffice, or for that extra measure, use both! Good luck !
| There are none. |
