Sump pum check valve
Posted by Doug on July 10, 2001 at 11:39:01:
I need to install a check valve on my sump pump. The pipes are PVC. Can I use a brass check valve with threads on both ends? If yes, do I need to do anything special like teflon tape the threads or use pipe compound? Thanks in advance
Replies to this post
