| Posted by hj on July 10, 2001 at 07:59:34: | |
| In response to Re: welding copper tubes on my heatpump | |
When you buy it ask for SilFos, the store will know what you mean even if they have a different brand. : : The system is under much higher pressure so you should silver solder or braze the joints. : : : can i weld the pipes that that normaly contains the : O.K
| There are none. |
