Re: welding copper tubes on my heatpump
Posted by francois launay on July 09, 2001 at 19:46:17:
In response to Re: welding copper tubes on my heatpump
: The system is under much higher pressure so you should silver solder or braze the joints.
: : can i weld the pipes that that normaly contains the
: : refrigirant gaz the same way we weld home water pipes.
: : i have fixed a lea in my coil and need to weld back the pipes for the freon gaz.
: : can i use standard solder??
O.K
WHIT WHAT SOLDER SHOULD A BRAZE THE JOINT'S AND
WHEN YOU SPECIFY SILVER SOLDER ,WHAT DO I ASK FOR
AT THE STORE ?
JUST SILVER SOLDER?
THANK'S SO FAR THIS IS GREAT HELP
FRANCOIS
Replies to this post
