Re: fiberglass VS. porcelin
Posted by Chuck on July 04, 2001 at 18:14:12:
In response to Re: fiberglass VS. porcelin
Caste Iron is best. Will last longer, hold heat and reduce sound and will make you feel like your
stepping into something solid. They weigh over
350 lbs so it is more than a one man job.
The rest are a one man job and some feel like pool liners. They are usually less expensive and don't last as long.
Good luck.
: What are the pros and cons of fiberglass and porcelin tubs? Which is better? thanks for your help!
Replies to this post
There are none.
