| Posted by Chuck on July 03, 2001 at 18:59:18: | |
| In response to Re: Toilet Flange too high | |
Wax rings are cheap and flex supplies are easy to change. Give it a shot, just don't tighten too hard or you may crack the china.
: Unfortunately I am married so it is not a good option at this point to switch. Could I build up the floor under the toilet with plaster? Would a gap of 1/4 inch for the compressed wax ring work? : Philip : : Philip, : : All toilets are not the same. You may be able to find one that will accommodate the height of the flange. : : John
| There are none. |
