| Posted by Philip on July 03, 2001 at 16:31:25: | |
| In response to Re: HELP, I shut off main water to house and leak continues | |
It appears that the main shut off leaks. You can try closing the water company shutoff located outside. An alternative would be to open another water facuet that is lower (ie in the basement). This will give the water another way out. This should stop the water from reaching the facuet you are working on. : I took the single lever faucet handle cartridge out of the bathtub faucet thinking that that was the cause of the constant drip, drip, drip from the bathtub faucet. The showerhead above has never leaked and it doesn't now. I shut off the main water valve to the house before I started. I got the stem/cartridge completely out and THERE IS STILL A CONSTANT TRICKLE OF WATER COMING OUT OF THE PIPE IN THE WALL THAT THE
| There are none. |
