Re: Green main drain
Posted by hj on July 01, 2001 at 18:17:58:
In response to Re: Green main drain
It is lightweight PVC, class Sewer and Drain pipe. to connect it to standard sized pipes, it requires an adapter bushing since it outside diameter is less than the standard pipes.
: My cast iron house drain terminates at a no-hub connector into a white 45-degree coupling and then to a light green 4" pipe, which then runs to the septic box. What kind of pipe is the light green pipe? ABS? PVC? The pipe was installed about 15 years ago.
Replies to this post
