| Posted by gary minutoli on June 29, 2001 at 09:49:15: | |
I have a copper tee connection, one side of the tee has started to leak. I shut the main water valve and opened the faucet in the basement to drain the water in the line. The tee is located in basement close to the main. I spent 45 minutes using mapp gas to fix the solder joint, would not melt. What are my options? |
