| Posted by hj on June 27, 2001 at 09:16:15: | |
| In response to Re: Broken Cast Iron Flange | |
A hammer and chisel applied to both sides of the flange will remove it very quickly. Then a "clamp on" flange can be installed on the pipe after the old lead and oakum are removed from it. : Hi, : We just bought our first home. To our surprise, the toilet in the master bathroom leaked at the base when flushed. : If I decide to take this project on how should I proceed? Should I cut out the existing cast iron flange a few inches from the floor's surface : We have a terrazzo floor underneath the tile so I am not dealing with a wood floor. I would assume that I could just slide the PVC flange into place. : What are your suggestions for making this a DIY project; should I even dare?
| There are none. |
