Re: Low Hot water pressure with new valve
Posted by Paul on June 24, 2001 at 16:57:57:
In response to Re: Low Hot water pressure with new valve
I found that the pressure in my house is too low to drive the new pressure sensative anti scalding faucets for showers. I had to return my $450 faucet, buy a $25 "old fashioned" one with no pressure sensing, and then buy various separate brass parts to make the thing look good. This was only determined after much head scratching and finally soldering on temporary faucet on the hot water side to see what I had for flow. (My house is gravity fed so I only have 30lbs of pressure, but if you have a well with low pressure settings you could have the same problem).
Replies to this post
There are none.
