| Posted by Raul on June 22, 2001 at 09:51:13: | |
| In response to Re: shut off valve | |
: : The reason a LICENSED plumber is used for good work is because of the experience they bring to your job. Gate valves and ball valves both have heat sensitivity to the temperature that it takes to sweat copper leak tight joints. Trades people who are sensitive to the amount of hets an inexperienced fitter will apply to the joint sometimes use what is called a heat sink. The heat sink connects on the valve and wicks away the heat from the valve body while allowing adequate temperature for the good sweat joint. Contact a LICENSED plumber for good fitting non leak valves. : : : Thanks in advance ... : : Raul More, I did contact a LICENSE plumber. He came over and was smacking I went to a plumber's supply house. Got the material I needed. I rather hire a LICENSE plumber, but the professional work Do you know of any in the NYC area? Raul |
| There are none. |
