Re: garage floor drain
Posted by Steve on June 20, 2001 at 05:30:04:
In response to Re: garage floor drain
What does a triple basin entail, not only for my own sake, but so I'm sure job is done right should I hire someone to do it. I assume a triple basin is needed for sanitary sewer tie-in as well?
: It is not legal since garage run off has grease and oil in it and that will contaminate the soil if it goes to a dry well. Garage runoff is supposed to pass through a triple basin to separate the materials before it enters any drain system.
: : I want to install floor drain in upper level of existing capped garage. I have no way to tie into sanitary sewer. What options do I have? Would a dry well work?
Replies to this post
