| Posted by hj on June 18, 2001 at 08:34:51: | |
| In response to Re: noise after toilet is flushed | |
The noise is probably the ballcock closing so replacing it will cure the noise. You might also check your water pressure since high pressure will cause high velocity noises in a conventional ballcock as the aperture gets smaller while shutting off. : We have a noise that occurs after the toilet is flushed and the tank is filled. It sounds like a : On your web site there was a similar question asked and you replied it was the ballcock in the
| There are none. |
