| Posted by VABUGGY@ALO.COM on June 16, 2001 at 14:35:13: | |
| In response to Re: Bad pump??? | |
: Did you look at the pump impeller when you opened it? How is the impeller driven? Is there a keyshaft and key in the keyway that is missing? Is there a setscrew that isn't fully tightened, and the impeller will only push half a load? Do you have a similar pump you can install in place of this one. to see if another pump does the same thing? Whats the cost of a new pump? $ 48 dollars? Whats the cost of your time? Two days on a pipe leak? :
| There are none. |
