| Posted by hj on June 16, 2001 at 08:47:32: | |
| In response to Re: copper pipe lenght and sweating | |
That is strictly dependent on how hot you make the copper tube. Three inches can be long enough if you heat the joint properly. : What is the minimum lenght that a copper pipe should be before it affects the closest solder joint? : Thanks in advance ... : Raul
| There are none. |
