| Posted by hj on June 14, 2001 at 09:09:09: | |
| In response to Re: shower fittings | |
The Delta Monitor, top of the line model, has a large volume control handle and a smaller, presettable, temperature lever. It is the only one I use for single handle installations because of that capability. You ccan either attach the unit to a standard shower arm or you can get a shower elbow from the unit's manufacturer which lets the hose drop straight down next to the wall. : Hi. I am renovating the tub/shower unit I have to replace the faucets, valves, etc. I currently have a tub spout, shower arm/head, and three handles -- one for cold water, one for hot, and a diverter to switch between spout and shower head. For the new stuff, I wanted to use a handshower with hose in place of the shower head. It is important to me that I be able to control not only water temperature, but also water volume.
| There are none. |
