Re: Teledyne Lars TGT50 Spa Heater
Posted by hj on June 10, 2001 at 22:46:16:
In response to Re: Teledyne Lars TGT50 Spa Heater
If the heater is too small, and yours may be, then it will eventually reach a point where it can only keep up with the heat loss. If that is not the problem then the thermostat is inside the unit behind the burner compartment door. It adjusts with a screwdriver.
: I have a Teledyne Lars TGT 50 gas spa heater. The water will not heat above 101 degrees. Can I adjust the thermostat on the heater to give me a higher temp and if so how? Thanks in advance for your help.
Replies to this post
There are none.
