| Posted by hj on June 08, 2001 at 23:36:29: | |
| In response to Re: Replacing pee trap under foundation | |
It depends on what you are doing. If you are moving it far enough to allow a no-hub replacement then that will be easier. : yes it is inside the bell. should I replace it with the same type of connection?
| There are none. |
