| Posted by hj on June 08, 2001 at 17:44:23: | |
| In response to Re: basement shower | |
Between the amount you will need to make the connection and still cover the "P" trap, you will be lucky to get it into a 10" thick floor. And you will need a vent between the trapnd the drain pipe. : I want to install a shower stall in my basement without busting up the floor. My idea is to tap into the main drainage just above the concrete floor; which after adding the slope and trap, I'm wondering what the minimum clearance is I'll need to frame up the base?
| There are none. |
