| Posted by tony decrescentis on June 08, 2001 at 17:14:29: | |
| In response to Re: Kohler Wellworth Toilet | |
I just installed a KohlerWellworth toilet and it works great. Check and make sure that all of the in-tank hardware is in place correctly. Also, check to see that there is no obstruction at the wax seal/ring locationwhere the toilet is supposed to discharge. It should work very well, by flushing quickly and the flap seal coming down quicklyto keep the flushing water from exceeding the 1.6 gal per flush limit. It sounds as if there is an obstruction of the discharge end. tony
: I removed my toilet a year ago and just recently : Thank you, : Joe
Kohler Wellworth toilet with Ingenium Flush |
