Re: Outside shower
Posted by More on June 06, 2001 at 04:49:40:
In response to Re: Outside shower
Do you know what a soffit is? Build a framework for your supply piping and drainage to hold the valves away from the wall to allow insulation, and yet secure, and place stop blocking to allow you to attach log siding to the framework using long drywall screws. Will there be a floor? or just natural drainage. Paving blocks will give a good non skid surface
: I will be installing an outdoor shower on my LOG home. Being that it is log I will not be able to recess pipes or mixing unit into the wall. Anyone have any suggestions on a profesional looking install, so as not to show all the tubing and mixing unit?
Replies to this post
There are none.
