| Posted by Ric Conover on June 04, 2001 at 15:55:44: | |
Recently purchased an existing home that had been "updated" with a Briggs low volume flush toilet. The flush valve is solid brass/bronze and nothing like I have ever seen before--with a take-off that feeds into an ejector for the rim flush. The valve is like nothing I've ever seen before, and like nothing available at Plumbing houses or home centers, and the standard valve will not work--fit and function. I have a one-year home owner's warranty on the house--including the plumbing. I contacted them, and in turn had a plumber authorized to fix the problem. However, I feel the "fine print" in the warranty is going to bite me--"...toilet bowls and mechanisms(replaced with builders standard as necessary..."). I feel they are going to give me a problem since this toilet seems to have no "builders standard mechanism." What can I do--and oh by the way, the valve is leaking badly enough to keep my septic field really green!!! Thanks!! |
