| Posted by hj on June 01, 2001 at 09:49:17: | |
| In response to Re: compression fitting and copper pipe | |
You can do it the plumber's way and use a reducing coupling to sweat them together, or the refrigeration mechanics's way of slipping the smaller tube into the larger one and brazing them together, depending on what the application is. : How do you connect 1/2 (o.d.) inch soft copper tube to 1/2 (i.d.) inch hard copper pipe? : Thank you : Raul
| There are none. |
