| Posted by Terry Love on May 28, 2001 at 13:11:57: | |
| In response to Re: Cementing around basement toilet flange | |
![]() : : : I broke up the floor, the plumber came in and re-plumbed the basement bathroom sewer line, and now I'm re-cementing. However, the flange (3" Sioux Chief T.K.O. pvc) is sticking above the floor line (1/4" to the bottom of the flange, 7/8" to the top of the flange). : : Brad, : : If you have the toilet you will be installing, you can check now. : : I'm thinking without seeing what you have, maybe vinyl, tile no problem. : I do have the toilet. Should I knock out the prior to setting the toilet base on? Do I need the wax ring to determine proper height, or does that not matter? I would do it first with the knockout in place. You want to leave those in as long as possible. You would be surprised to know what gets thrown down there during construction.
| There are none. |
