| Posted by Karl on May 26, 2001 at 18:53:17: | |
I have a Kemore (super capacity genius plus) water softner. It has been installed 5 years. About 2 days ago I discover a leak near the bypass installation valve. It is dripping, slowly, from the inlet side. I disconnected the valve body from the bypass installation valve and check the o-rings. Though they looked OK, I replaced them with new one, lubed them with a little petroleum grease and reconnected the valve body. Still leaks. To make a long story short I have moved, adjusted and tweaked the position of the softner and can not stop the leak. Any ideas? |
