Re: Shower Drain Replacement
Posted by hj on May 20, 2001 at 09:19:36:
In response to Re: Shower Drain Replacement
Go through the ceiling. By doing this, you can verify where the leak is and fix it through the same opening.
: We recently purchased our home in December and this month we noticed water coming through the ceiling of our garage. I traced the leakage back to the shower drain in the master bedroom. I noticed to properly fit the new drainage, I would need to access under the shower pan. Should I remove the shower pan or access through the ceiling of the garage?
Replies to this post
