Re: Raising toilet flange to new flooring height
Posted by Brian on February 17, 2004 at 17:24:20:
In response to Re: Raising toilet flange to new flooring height
I had a similar problem. I found a kit at Lowe's that includes stackable flanges and rubber gaskets to go between them. You stack them onto the existing flange. Each piece is about 1/4 inch high, and two come in the kit, so one kit should work for you. In addition, I used a wax ring with a sleeve - just in case the gaskets leaked. The combo seems to be working well.
Replies to this post
There are none. |
