Re: Shower Drain in slab
Posted by Terry Love on May 26, 19100 at 14:44:46:
In response to Re: Shower Drain in slab
: I am installing a new shower on a concrete slab and have roughed in the 2" pvc line. My question is whether I should use a solvent welded pvc drain or a brass drain with rubber seals in this installation -- I'm not impressed with the rubber seals in the brass fitting, but I'm worried about the permanency of the solvent welded joint.
Either one will work. The solvent welded joint is permanent. The advantage of the rubber joint, is being able to lift off the pan when needed. Terry
Replies to this post
There are none.
