| Posted by Henry Benway on May 26, 19100 at 09:47:46: | |
I have an oil fired hot water furnace. The furnace is circa 1950-60. The heater registers are large finned units with 4 copper tubes running through each. the covers are large 32(H)x12(D)x48(L). I need to move one of these regesters 4 inches to the left. I plan cut the 2 in/out pipes, in the cellar, about 2" below floor level; lift the register out; drill new holes 4 inches to the left; insert register in new holes; adjust pipe length in cellar; & reconnect using compression fittings. Any one see any flaws, or 'gotchas' with this plan. I need to drain the water lines before I start the above. I willdrain the storage/holding tank. But are there additional valves I should look for, to also drain? Appreciate any & all advice. |
| There are none. |
