| Posted by dick on May 25, 19100 at 15:26:02: | |
| In response to Re: A click off of norm. | |
you need to do some homework if your going to play boat designer. large dia pvc pipe is flimsey and heavy. a simple calculation will show that a 22: od pipe x 12'(the biggest i could find specs on) will support a maximum of 1915 lbs. Unless you want some really bad handleing and loading characteristics, a round pontoon shouldn't be loaded over 50% that limits you to 957 lbs, from that you subtract 60 lbs for the pipe, 30 lbs for the ends (a guess), and probably another 100 lbs or more for mounting the pipe. The stuff really is flimsey so it needs a lot of support. So far you have a 767 lb available payload on a pontoon that weighs 190 lbs. Not a good ratio. And you still have to do something about protecting the pipe from bottom contact or internaly bracing it so it doesn't break in half when you ground out on a log.
| There are none. |
