Shower Drain
Posted by Don Karg on May 25, 19100 at 11:51:47:
I am installing a new shower on a concrete slab and have roughed in the 2" pvc line. My question is whether I should use a solvent welded pvc drain or a brass drain with rubber seals in this installation -- I'm not impressed with the rubber seals in the brass fitting, but I'm worried about the permanency of the solvent welded joint.
Replies to this post
