| Posted by murphyplumbing.com on May 25, 19100 at 11:09:31: | |
| In response to Re: closet flange height | |
: I'm installing a new sub-floor and tile in the bathroom. Because of this the floor height will be considerably higher. What is the proper way to raise the existing height of the toilet flange (it is cast iron). you can install what is called a stack ring. it bolts to the existing flange and will bring the flange up to the proper height. very quick and easy to install. |
| There are none. |
