Re: no hot water
Posted by on May 24, 19100 at 21:39:51:
In response to Re: no hot water
: My hot water heater quit. I have tested to make sure it was getting electricity to both elements. It is getting it but still no hot water. The heater is only 2 yrs old. I would appreciate a reply.
you may be getting electricity to the elements though the element or elements could still be bad. you will need to test the elements (with the electricity off!) with a continuity tester. if you have no continuity you will need to replace the element.
Replies to this post
