| Posted by dick on May 22, 19100 at 10:38:55: | |
| In response to Re: Converting propane grill to natural gas | |
You need bigger jets, and some plumbing/tubing fittings. The problem with the grill is that natural gas pressure is lower than the propane pressure that the grill was designed to operate on. In order to change over you will need to purchase larger jets, or drill out current jets. How big??? or where do i buy bigger jets???? That is the problem!!!!!!!!!!!!!!!!! Due to liability concerns, manufacturers and dealers are very reluctant to sell jets or give out any information on converting. some just say conversion is not possible. This means you are on your own drilling out the jets. Before you start, it might be prudent to buy a set of replacement jets from the manufacturer, or get the jets out of an old grill. : I'd like to hook up my propane grill to my natural gas line from my house. Do I need a special burner or a conversion kit? Where would I get such an item?
| There are none. |
