| Posted by joe on May 20, 19100 at 10:57:27: | |
| In response to not enough water in toilet | |
: : I have three toilets in my house, and two that are upstairs have a problem flushing. The water will not go : : all the way down. It just spins. The one downstairs works fine. All three are the same model. : : Gerber K 1983 : : I replaced all the mechanisms in the toilets but that did not seem to help. : It sounds like something is in the trapway of the toilets or the waste line is backed up to the upper level. Nah! that's not going to happen. You may need to give them a good plunging, snaking or even remove the toilets and inspect from underneath. Good Luck,
| There are none. |
