Re: Appropriate copper to use for propane
Posted by Curt on May 18, 19100 at 08:33:31:
In response to Re: Appropriate copper to use for propane
Sorry, meant to say Type L is the thicker type (Gotta remember the order of the alphabet). But iron pipe would be a better choice, and a plumber installing iron pipe your best choice.
: If I understand, you want this pipe to carry propane. I'm not a plumber, but I believe in some areas code allows soft copper for propane/NG to be used indoors only if it remains exposed. For example, running to a water heater in an unfinished basement is OK (at least in some areas). Black pipe should be used if hiding in a wall or ceiling so it cannot be accidently punctured.
: Type M is thicker walled pipe. Either probably is as effective for propane.
: : We are installing two new water heaters upstairs in our home. What grade of 1/2" soft coil copper should be used - M or L. Any suggestions before we run the new line to the new water heaters?
Replies to this post
There are none.
