| Posted by Curt on May 17, 19100 at 09:06:01: | |
| In response to Re: Appropriate copper to use for propane | |
If I understand, you want this pipe to carry propane. I'm not a plumber, but I believe in some areas code allows soft copper for propane/NG to be used indoors only if it remains exposed. For example, running to a water heater in an unfinished basement is OK (at least in some areas). Black pipe should be used if hiding in a wall or ceiling so it cannot be accidently punctured. Type M is thicker walled pipe. Either probably is as effective for propane. : We are installing two new water heaters upstairs in our home. What grade of 1/2" soft coil copper should be used - M or L. Any suggestions before we run the new line to the new water heaters?
