You need a shower drain with a Roman tub top. That gives both the drainage and the stopper. : I want to install a custom tile bathtub about 12 inches deep. I am planning on building it like a : standard tile shower base - cement board backer, mortar bed, liner, mortar, tile. My problem is : the drain. Standard bath tub drains don't have the means to drain water that leaks below the tile : but above the liner, and standard shower drains don't have a stopper and overflow openings. : What kind of drain do I need? Are there any other problem with a tile tub that I should know about? : Would it be better to use a copper or lead liner instead of a plastic membrane? What about code : requirements � anything special I should know? I have the sneaking suspicion that there is something : wrong with my plan since you see so few tiled tubs.
