Re: septic system removal??
Posted by hj on May 15, 19100 at 23:28:00:
In response to Re: septic system removal??
More important than the septic tank which is relatively shallow is the cesspool if you have one, and if it is not one which had vertical pipe and was filled with stone. If you should have an open pit cesspool, it is very important that it be opened and filled with dirt, stone, or other material before the cover weakens and someone drops into it.
: what should i fill my old septic system with?? It has been out of use for at least 10 years. Any thing I should know before hand? Any info would be appretiated!!Thank you!!!
Replies to this post
There are none.
