| Posted by murphyplumbing.com on May 15, 19100 at 19:10:07: | |
| In response to Re: chronic pressure relief value problem | |
: I'm in a three year old house that originally had an electric hot water heater. The pressure relief valve would let loose every four months or so - When we finally realized where the water in the basement was coming from, we were in the process of switching to a gas water heater (late last year). The new water heater is playing the same game. Could I be experiencing high line pressure from the county? Or am I just lucky enough to have recieved two defective relief valves. I am considering a PRV and /or new relief valve. BTW, when it blew tonight, the relief valve would resume discharging cold water at full flow a few moments after turning the water back on. Does anybody have some wisdom to share on this? Thanks in advance. a pressure relief valve will blow if the water pressure is to high, check this with a guage that you screw onto the end of a hosebib. if its over 80 lbs you should install a pressure reducing valve on your main water line.
| There are none. |
