Re: high watter table effecting the performance of my septic system
Posted by Dale's Plumbing Service Inc LMP on May 15, 19100 at 18:31:38:
In response to Re: high watter table effecting the performance of my septic system
: : terry i live in a area with a high watter table I have noticed that when it rains heavy my basement toilet flushes verry slowly. Will a ejector pump help solve my problem? also will a ejector pump prevent watter from backing up into my basement through my septic tank?
: If your waste system if gravity now, adding the pump will not help. For the pump to work, it needs a free flowing drain to dump into. If your drain is slowing down, Whoah! Don't add more water to it that quickly. Terry
You need to install a raised mound system. That will get you above the water and does require a pump. Dale's Plumbing Service Inc LMP
Replies to this post
There are none.
