| Posted by brian on May 14, 19100 at 19:27:20: | |
| In response to Re: connecting ice maker supply to Qest | |
: Saddle valves are a problem with copper, and shoould not be used on flexible plastic. Get a 3 way stop for the sink's cold water supply and connect the icemaker to it. : : Hi Terry, : : Thanks, never had a problem with saddle valves on copper or on quest, you will most likely cause more problems trying to change angle stops than using a saddle valve. ????? |
| There are none. |
