: Stuck in South Africa with a blown Flushmaster valve riser seal. Trying to find supply for replacement seal because the whole valve hase been buil around so I cant fit a new assembly. Any help? : Toilet sweating at the summer house..can't install temperance valve : : 'cause there is no access to the supply line without ripping up the entire floor. : : was thinking a flushmaster equipped toilet would help but the bowl itself is sweating any help would be appreciated : : Thanks
: Steve, : A sweating toilet is working too hard. Cut it some slack and replace the flapper. These should be replace every five years. If you see water draining into the bowl, bing! that's the problem. Terry
