| Posted by Dave V. on May 08, 19100 at 15:13:25: | |
Recently, I asked here if Gerber toilets used a special tank-to-bowl gasket, since the new one I'd installed leaked like a fire hose. The answer was: Yes. I located the gaskets locally and installed one. The result was a small leak (much smaller than with the "normal" gasket, but a leak nonetheless). I tried the other new gasket, just to be safe (I bought 2 gaskets while I was at the plumbing store), with the same result. The guy at the store suggested I wasn't cranking the tank down tight enough, but I'm afraid to tighten the bolts any tighter for fear of cracking the bowl. Several questions arise: 2) I replaced the bolts at the same time. These bolts have a rubber washer directly contacting the tank on both the inside and outside surfaces. The inside gasket is snugged up by the bolt head. The outside gasket by a washer and nut. (That assembly is installed with the tank totally off the bowl). The tank is then held to the bowl by a washer & wingnut, which is what I tightened to the point of being afraid. Does that sound right or wrong to anyone? 3) There were 2 or 3 little black rubber "cushions" between the tank and the bowl. They fell off when I removed the tank the first time, so I'm not sure where they should be. Could misplacing those be causing my leak? I really hate to call in a plumber for such a minor issue, but I'm really not sure what to do next. Any and all suggestions are greatly appreciated. If I need to provide any clarifying feedback, I'll be glad to. Thanks!!! |
