| Posted by Dale's Plumbing Service Inc LMP on May 07, 19100 at 00:33:24: | |
| In response to Re: Toilet Leak | |
: This only happens every 3 or 4 months. While flushing the toilet a gurgling sound comes from the bathtub drain and a large amount of water leaks down on the first floor. It does not appear to be dirty water, the water looks clear. I have replace the wax ring a couple of times but this seems to reoccur. Would like any help you can give : Thanks The gurgleling sound is saying you have a partically blocked drain line .It may be causing the drain water to back up into the vent where there may be a leak in that line. Dale's Plumbing Service Inc LMP |
| There are none. |
