| Posted by Terry Love on May 06, 19100 at 15:45:29: | |
| In response to Re: How much h2o pressure is too high? | |
![]() Most plumbing codes require a pressure reducer if the pressure is over 80 PSI. Things to consider when adding a reducer. Water pressure is determined by the height of the water tower, or the setting of the pump. The distance down from the source affects water pressure. People at the lower end of the hill, will have higher pressure to deal with. Those at the top, sometimes have "very" low pressure. For those, you can buy "pressure booster systems". Terry |
| There are none. |
