| Posted by Randy Williams on August 15, 1998 at 22:26:06: | |
My tub faucet and drain is not working properly. A. The drain has a up/down lever to keep the water or drain it and when it is on drain the tub drains very slowly unless you hold the lever in the down position then it will drain more rapidly. B. The faucet has a pull-handle to direct the flow of water to the overhead shower. The pull-handle is very difficult to pull most of the time and will loosen up only when I put WD-40 on it and that only last a little while. I want to replace the faucet but cannot figure out how to disassemble it without knocking a hole in the wall. Any suggestions?? Thank You :>) |
